  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Smart UPS RT 8000 XL discharges batteries on Self-Test
  • Communities
  • Re: Smart UPS RT 8000 XL discharges batteries on Self-Test
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
kazuzapt_apc
Crewman kazuzapt_apc
Posted: ‎2021-06-29 04:58 AM
595
This was originally posted on APC forums on 11/29/2012
Good afternoon all
I have in my facilities the above UPS and got indication to replace batteries a few weeks ago..
Replaced batteries (all four of them) with original RBC44 (2 of them) and put it into production
Now after leaving the unit charge batteries for 2 days now, i get indication that batteries are 100% charged, 217VDC on them, but as soon as I perform a self test, i get events that batteries are too low to support the load (when actually there is NO LOAD) and charge percentile drops to 14% and increments there on to 100% in a few hours. Repeating the self-test again produces the same result in a infinite loop
I have no events regarding any failure whatsowever
Am I missing something, or do I have a problem in my unit?
Thanks for any help regarding this issue
kazuzapt_apc
598
This was originally posted on APC forums on 12/3/2012
Thanks for all your input i picKed a winna
However that did not solve my problema. Neither calibration nor discharging with a 30% load until exhaustion
Had to remove the 9631 card and entered via serial port into SM where I could reset the UPS to state 8C
After comproving correct functioning, inserted network card again and everything is working now
Thanks for your help
Replies 3
This reply was originally posted by Angela on APC forums on 11/29/2012
how much battery runtime does the UPS report? i am assuming it is because it is within two minutes of the low battery signaling time which defaults to two minutes.
if these are geniune replacement batteries, i suspect you just need a runtime calibration to tell the UPS you have new batteries. you should generally do this with a load on the UPS of at least 30% and make sure it does not fluctuate. the management card installed can execute the calibration for you or you can do it manually if you'd like and remove power from the UPS and let it turn off completely and charge back up. if you do the calibration via the management card, it will discharge the UPS to about 10-15% and then charge back up incase you don't want the attached load to shutdown hard.
kazuzapt_apc
599
apatel777
apatel777
Posted: ‎2022-03-13 10:39 AM
In response to kazuzapt_apc
I have the same challenge after battery replacement, shows discharged battery warning, 0 mins runtime and not calibrating.
With regards to this solution - Had to remove the 9631 card and entered via serial port into SM where I could reset the UPS to state 8C
Can you advise what you mean by state 8C, is this a simple process, does it require everything to be unplugged from UPS?
Additional options
