Need legacy Firmware for AP9641
Send InviteCancel
Posted: 2026-10-2602:18 PM
I recently got a 9641 NMC that has an older version of firmware. I believe my issue is that the firmware is too old to be directly upgraded to the current version. I believe that I need to go from 2.5.0.6 to something in the 2.5.2.x or 2.5.3.x range before upgrading to 2.5.5.1. I cannot find legacy firmware anywhere? Does anyone know where to find that or if I'm barking up the wrong tree?
Posted: 2026-10-2702:34 AM
I’m not exactly sure what you’re asking vs what the actual problem is?!?! As such will offer some guidance and perhaps it will help resolve the issue.
Generally speaking it’s best practice to upgrade the firmware in a staged manner especially if it’s from a major branch revision such as 5.XX -> 6.XX -> 7.XX.
Minor revision such as 2.5.0.X -> 2.5.5.1 have no effect.
The following action items and steps will yield the best results:
Wizard: Launch the firmware wizard as a an Administrator on the Windows OS. Enter the credentials for the Admin / Super User. Input the target NMC IP Address. Select FTP and do (NOT) save logs.
Start the firmware process and let complete. Once the pop up message appears that the update has completed wait another ten seconds before closing the pop up dialogue box.
If you require a specific version of NMC firmware you’ll need to contact APC Technical Support to obtain the same.
Lastly, you may refer to the APC NMC FAQ for alternative methods and resources:
Posted: 2026-10-2812:34 PM
Thank you. The solution for me was to disable https and scp. The encryption overhead made the software wig out while trying to process the large file. Once I disabled those and used ftp for the process, it was able to handle the upgrade to 2.5.5.1. I have since re-enabled https.
