  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
208/120 volt supply vs 240/120 volt supply
  • Communities
  • Re: 208/120 volt supply vs 240/120 volt supply
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
NWIGenerator_apc
Crewman NWIGenerator_apc
Posted: ‎2021-06-30 10:54 PM
376
This was originally posted on APC forums on 12/27/2015
I have an older APC UPS model number SYAF16KRMT currently connected to a 208 volt feeder.  I would like to know if the current connection without modification could be powered in an emergency situation with a 240 volt power feed.  Any assistance is greatly appreciated.
  • back-ups
  • feeder
  • generator
  • power
mitsmith_apc
Lt. Commander mitsmith_apc
This was originally posted on APC forums on 12/29/2015
Hi Chris,
Yes it will only be when the generator is supplying the power that you will experience issues.
Replies 4
NWIGenerator_apc
The rating of the equipment is 120/208, 120/240
mitsmith_apc
This was originally posted on APC forums on 12/28/2015
Hi Chris,
The symmetra Lx can take 208 or 240. When you get the 240volts in the unit will still output whatever you have it set at (I am guessing 208volts). The issue is when you have 240V in and 208V out you will likely get a bypass out of range error message. If the unit has a reason to go to bypass (overload or other internal fault) it will not transfer and will just drop your load. It is designed to do this to protect your load from a sudden jump in voltage (208 to 240).
As a standard we always recommend outputting the same voltage that you are inputting (208 in 208 out or 240 in 240 out) to prevent any abnormal behavior with the unit.
NWIGenerator_apc
Thank you Mike.  That is exactly as we thought.  To be sure, in this case, this will only occur when the automatic standby generator is in use to power the UPS (extremely rarely).  I feel safe that we will not cause harm to the UPS.
mitsmith_apc
Hi Chris,
Additional options
