Welcome to the new Schneider Electric Community
It's your place to connect with experts and peers, get continuous support, and share knowledge.
Important Announcement: WELCOME to the new Schneider Electric Community! Community is now no longer part of Exchange, and is now rebranded under se.com. If you have any bookmarks and links saved, we request you to update them to ensure that you continue accessing our community from this new location. For any issues that you might encounter as part of this change, please reach out to SchneiderCommunity.Support@se.com, and the team will help to get your issues resolved.
Send a co-worker an invite to the Exchange portal.Just enter their email address and we’ll connect them to register. After joining, they will belong to the same company.
82195members
349797posts
Smart-UPS SC 1500 - Under voltage detection, UPS stays on battery power.
APC UPS Data Center Backup Solutions Forum
Schneider Electric support forum for Data Center UPS, software and services including our APC offers designed to share knowledge, installation, configuration, and general product use.
Administrator Administrator
This question was originally posted by Milan on APC forums on 8/30/2020
Hi all,
I have an old version of APC Smart-UPS SC1500, which was running fine with replaced batteries after not being used for over 3 years.
But just after latest blackout, the UPS just won't go back to normal power from the wall.
After checking it with PowerChute it shows that the battery is running good, self-test passed, and it's charging the battery fine.
The only thing is input voltage is way under and fluctuating between 166 volts up to 204 volts. When it's on 204v it boots up normally, tries to stay on outlet power but keeps failing, when I checked again with PowerChute it shows 192v or less.
I've checked the power outlet and it's on acceptable voltage of 215 volts.
So, I was wondering if anyone had the same experience and how to solve it.
Does anyone know if there is a component that is failing and might need replacing?
Cheers.
