82394members
349890posts
Shutdown due to 016 DC Bus Low
276
This question was originally posted by Mukhtar on APC forums on 1/27/2016
I am facing problem with SRCPM6KI. When I try to turn ON inverter all tests(frequency out 50Hz,input 230 50Hz,Rectifier OK, Charger OK, Battery OK, DC Bus OK, Inverter Test OK) passed but at the end when UPS self test started red warning light lit with beep sound and showing shutdown due to 016 DC Bus low. Secondly I want to download its logs from UPS brain. NMC not installed in this unit. Kindly help to resolve the issue.
Mukhtar
sanjaym_apc
Re: Shutdown due to 016 DC Bus Low
This was originally posted on APC forums on 12/9/2016
Problem solved pls give me solution i am facing
3 Replies 3
This reply was originally posted by Bill on APC forums on 1/27/2016
It would be beneficial for you to contact local technical support concerning this issue. Contact information can be found at this link http://www.apc.com/site/support/index.cfm/contact-information/
This reply was originally posted by Mukhtar on APC forums on 1/29/2016
OK. Agreed. But just for information can we download event logs. And is there any calibration parameters of this UPS
Mukhtar
sanjaym_apc
