Follow along for an enriching discussion with our CEO, Peter Herweck, and industry leaders for a captivating Global Keynote at #InnovationSummit Paris 2024. Watch recording and join the #ImpactMaker movement!️
SYRXR4 Not Reporting Correct Battery Statistics Usage ?
Send InviteCancel
Posted: 2021-06-2901:12 AM. Last Modified: 2024-03-1311:24 PM
We have recently installed a Symmetra 6kva with the Extended Run Frame, and found that 4 out of 5 Extended run frames are not reporting the correct charge on the batteries.
When the SYRXR4 is connected with 4 brand new fully charged batteries installed, the Symetra front panel as well as the Power Chute web interface report battery charge at 57%. When we pull the same batteries out and place them into the chassis, and disconnect the XR4, it reports at 99% charge. Whiskey Tango Foxtrot over?
The display correctly reports the 7 batteries installed, and from the Power Chute interface, they all check in as "Good" ... It is only when the XR4 is connected that we are getting the wrong charge information. Any ideas?
Quality control on this order has been horrific. 6 out of 9 Symmetra 6kva chassis showed up with the back ends dented and the fan modules crushed in the exact same place as if they came off the production line this way. I can say this with a fair amount of certainty, as the APC boxes they are packed in are pristine, and everything is still in the plastic. 2 battery modules' pins broke off in the XR4 when attempting to remove them when the XR4 would not report the correct charge. Two other XR4s see the batteries, but will not report the charge ... and one of the Intelligence Modules pins had bent and broken pins coming right out of the packaging ... That factory in China manufacturing the AMERICAN Power Conversion components needs some oversight.
I am not feeling good about selecting APC over Liebert for this order. Hopefully the APC customer service makes up for the lack of quality control in their manufacturing.
