This question was originally posted by Joe on APC forums on 1/10/2016
Hi Folks, I have an SMT3000 that was running on firmware SMT18UPS_09-1.enc and I attempted to upgrade the firmware to SMT18UPS_09-3.enc via the installed NMC firmware update mechanism. I powered down the UPS and logged into the NMC, located the correct firmware will under the "Configuration/Firmware Update" drop down and proceeded. The front panel of the SMT indicated that it was accomplishing the firmware update and the screen on the NMC web interface said that it would restore after the firmware update was successful. The NMC screen restored and I attempted to turn the UPS back on and now it appears to be dead with a constant tone coming from the UPS' alarm. I have verified that the battery packs are good.
The NMC interfaces shows the following:
HOME:
Smart-UPS 3000: Unknown |
2 Critical Alarms Present |
- An internal UPS communication fault exists.
- The battery power is too low to support the load; if power fails, the UPS will be shut down immediately.
2 Warning Alarms Present |
- The power for the main outlet group, UPS Outlets, is off.
- The power for switched outlet group 1, Outlet Group 1, is off.
Recent Device Events |
01/10/2016 |
11:19:34 |
UPS: The power for switched outlet group 1, Outlet Group 1, is off. |
01/10/2016 |
11:19:34 |
UPS: The power for the main outlet group, UPS Outlets, is off. |
01/10/2016 |
11:19:34 |
UPS: The battery power is too low to support the load; if power fails, the UPS will be shut down immediately. |
01/10/2016 |
11:19:34 |
UPS: An internal UPS communication fault exists. |
01/10/2016 |
11:19:34 |
UPS: Restored the local network management interface-to-UPS communication. |
STATUS:
UPS Status Smart-UPS 3000 |
Last Battery Transfer: |
None |
Battery Temperature: |
0.0°C |
Runtime Remaining: |
0min |
UPS Input |
Input Voltage: |
0.0 VAC |
@ 0.0 Hz |
UPS Output |
Output Voltage: |
0.0 VAC |
@ 0.0 Hz |
Load Current: |
0.0 Amps |
Output VA: |
0.0 % |
Output Watts: |
0.0 % |
Output Efficiency: |
output off |
Output Energy Usage: |
711.90 kWh |
Battery Status |
State of Charge: |
0.0 % |
Battery Voltage: |
0.0 VDC |
I can no longer attempt a firmware update because the NMC thinks the UPS is turned on:
Does anyone have any ideas on how I can proceed or need any additional information that may be helpful?
Any help will be greatly appreciated and thanks much!
