Posted: 2021-06-29 02:41 AM . Last Modified: 2024-03-13 03:21 AM
I have a mini-cluster that is supported by 5 3000VA APC UPS with NMC installed.
I was trying to use the sensor reading data to monitor the cluster status but not successful.
Reason:
1) I tried email/syslog/snmp notification however they only export event, but not data;
2) I tried data log rotation however the minimum interval of 1hrs is way too long. I'd desire 10 min since this is the internal data log interval;
3) I tried to actively ftp the data log out however it has to be interactive - cannot use password-less authentication;
4) data.log does not contain battery temperature data.
Any workaround? Or could you please allow such options in the next update of the AP9631 firmware? Thanks.
Message was edited by: leizhoucn
Okay, so you basically want it FTPed every time it updates.
I've done this using python and ftplib.
You could poll the data points yourself using SNMP. That way you can go as fast as possible and record any data point. The NetSNMP utilities should help with scripting it. The GetIF utility is great for experimenting and playing around with SNMP. You'll also need the [PowerNet MIB|http://www.apc.com/resource/include/techspec_index.cfm?base_sku=SFPMIB403] which describes the SNMP capabilities of APC devices.
I think one possible think that you do is to create a script that would access the NMC using FTP and then download the datalog.txt
